Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Heater/AC problem
Old 01-05-2017, 09:00 PM
Johnusa's Avatar
Johnusa
Johnusa is offline
Default Heater/AC problem
When I turn on the de-froster on high, It blows ice cold air......... I put my hand on the aluminum A/C tube, and it was ice cold...........obviously the air condtioner should not be running when the defroster is on.
Which fuse can I remove to disable the A/C ??
2010 Dodge Caliber
Old 01-05-2017, 09:14 PM
Johnusa's Avatar
Johnusa
Johnusa is offline
To clarify my problem: I want to dis-able the A/C compressor ....without affecting the defroster...... Can this be done by removing a fuse ???
Old 01-06-2017, 12:20 AM
p38251's Avatar
p38251
p38251 is offline
Nope. All the new stuff uses the ac system when defrost is selected. you have something else going on. May want to look on caliber specific web site.
Old 01-06-2017, 10:31 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Have you given it a chance to warm up? Or is this immediately after cranking it up? As stated, defrost function uses AC comp to dry the air (most vehicles since the late 90's do this). This works on any temp setting.
Old 01-06-2017, 11:37 PM
Chet Ubetcha's Avatar
Chet Ubetcha
Chet Ubetcha is offline
3rd Gen Ram Moderator
Is this for the Caliber or a Dodge Ram? If it's for a truck, I'll move it back. PM me.
Old 01-07-2017, 06:16 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Sounds like a blend door issue if you are getting no heat. As mentioned, the a/c runs for 2 reasons. 1 to remove moisture from the air to defog the imside of the glass. 2 to keep the system in use in the colder seasons to keep the seals from drying out and leaking.
Quick Reply: Heater/AC problem
