RE: 2000 Caravan a/c and heat problem
The fan blower 'resistor' is bad.......when you turn it to high, it runs on full 12 volt power(no resistor) Any setting less than high just directs the current thru a series of resistors for less voltage/ less speed.
Don't know where yours is located......my 93 is in the firewall, between the hood hinge and the fender.
I've seen some 'inside' the blower motor encasement....?
Looks like a large relay.....2" wide by about 3" long?? Just plugs in.
Hope this helps some........nothing wrong with the motor if it goes on high, eh?
..............Ol'Ben
__________________
PATRIOTISM MEANS TO STAND BY THE COUNTRY. IT DOES NOT MEAN TO STAND BY THE PRESIDENT. - ATTRIBUTED TO PRESIDENT TEDDY ROOSEVELT.
