HELP - no brake lights
2000 dodge grand caravan. I have no brake lights. Blinkers, Emergency flashers, and back up lights work. I did install a "Hoppy" trailer wiring kit about 2 years ago, so I dont think that has anything to do with it. I have checked the fuses both under the dash and under the hood, as well as the bulbs and wiring. I got nothing. I'm stumped. I am a "shade tree mechanic" but I've never seen this before. Thanks for any help you guys could give.
RE: HELP - no brake lights
OK I've checked the brake wiring for a bad ground or anything that might signal a problem and I have checked the fuses , what are the chances it could be the brake light switch behind the brake pedal, do they go bad ? Does it happen often ? Is that the only other thing is could be ? I dont know what else to check. thanks
