DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-05-2007, 04:12 PM
marmas marmas is offline
Default How to replace EGR on 99 Grand Caravan
I just got my van dianosed with a faulty EGR valve.
My concern would be if it's simple enough for me to do it or do I need to have the shop do it. Appreciate any help.
Thanks much.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Grand Caravan SE
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-05-2007, 07:58 PM
asniff08 asniff08 is offline
Junior Member
Default RE: How to replace EGR on 99 Grand Caravan
i just put on a new egr for my 98 with a 3.3, it wasnt hard, although it is a tight fit for the wrench, also make sure to disconnect the battery, i forgot to at first and when i started loosening the egr valve sparks started to fly[8D]
Old 06-05-2007, 10:41 PM
floorslayer1 floorslayer1 is offline
Chances are all you really need to change is the vacuum solenoid which you get with the valve. Pretty easy change 2 10mm bolts with an extension, one electrical connector and a couple of Vac lines.... You'll do fine as long as ou get the air breather intake stuff out of the way, it really won't pay to try and work around it. Same 10mm socket for2 bolts on the air resonator and 2 philips screws for the band clamps and that pops right off. Good luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
