RE: Humming noise
Does the hum change pitch as you drive? I'd agree with asniff though, if it goes away when turning (or the bearing gets loaded with force) then it probably is a bearing. If you can do front brakes, then a bearing shouldn't be a biggie as these are just bolt-ons. Good luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
