DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-11-2007, 10:16 PM
dredwin dredwin is offline
Default Strut installed incorrectly?
So I spent Friday installing new struts (and shocks but those were easy) on my 98 Grand Caravan (3.3L). I had some is issues with the Monroe strut mate boots...eventually used the old/original bootone on one of the struts.
So, I think I installed it correctly (I did and undid it like 2-3 times on each strut...first I forgot the bottom rubber gasket thing the spring sits on...then I installed the Strut bumper wrong...or so I thought). Anyway, I though it looked good...most importantly, the spring is in the orginal position (I was smart enough to mark the spring and the postion of the old strut).
So I am test driving it after thinking I fixed the problem and it sounds like a little thump...from the top of the strut.I am guessing I didn't align it up correctly (this is the one with the new strut boot) and had issues with the strut and the cap.
I read other threadstalking about the sway bar bushing (I don't think it is that since my bushings looked good).Wouldthe sway bar links (which looked fine but I am not sure about the inside...is is just rubber?)
Or do I just need to tear it apart, use the original strut bumper/cover and make sure it is aligned properly.
Chime in with your opinions.
Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-12-2007, 02:35 AM
Dodge Tech Dodge Tech is offline
Default RE: Strut installed incorrectly?
links and bushing probs are on newer vans not yours
__________________
Work at a Chrysler,Dodge,Jeep Dealer<Master AC/Electrical/Engine Performance
Chrysler Dodge Jeep Tech for 11 plus years and do side work in ATLANTA if u need something done just email me.
http://home.comcast.net/~kkeller608/index.html
Old 06-12-2007, 07:10 PM
Thanks Dodge Tech...you seem to be very knowledgeable and helpful with everyone's questions.(based on other replies).
Old 06-15-2007, 04:22 PM
Update: I took off the strut again (and again) and finally figured out that problem. I guess I hadn't tightened the nut (on the top of the strut) enough so when I hit a bump, it rattled around.
Iused an impact wrench, grabbed a hold of the strut with my hand (so I wouldn't scratch the surface of the piston) and tightened it up...pretty much until I got blisters and couldn't holdit without it spinning on me).
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
