RE: Valve cover gasket
Most if not all are option 1 unfortunately. You can tell by the hold down bolts. The isolated type have a collar or spacer on which the bolt tightens. The standard type has the bolt bearing down directly on the sheet metal of the cover. I ran into this and found the price difference shocking--to the point thatI'll let my isolated cover weep a bit.
