DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-24-2007, 01:32 PM
redrooster redrooster is offline
Default 99 Dodge Caravan with Autostick
I have a 99 Dodge Caravan with Autostick that quit workijng. After talkingto serveral tranyshops and several dealers with no luck, I decided thatI would look to see if I could find the problem. Turned out thatone of the wires going to the Autostick control was broke. This is located on the shift lever. You have to remove all thecovers on the steering coloum to get at it. Simple fix. Also the clock spring needed replaced, this is a life time warenty on these vans.
Rooster
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-24-2007, 04:06 PM
next2pool next2pool is offline
Default RE: 99 Dodge Caravan with Autostick
I never knew that autostick was available on 99's--have never seen one!
Old 06-30-2008, 05:35 PM
boulderkc boulderkc is offline
I have to reiterate this was an easy fix.
I have a 2000 Dodge Caravan ES with autostick, same wire broken underneath. Dealer wanted $148 for the switch almost a year ago, I special ordered it. A month ago I prodded about the delay and this time they told me I had to replace the entire Steering column (at $895 for parts).
I found a "used" column (with auto stick) for 250 but before ordering it I decided to search again, found this and that gave me confidence to try. Thanks redrooster.
You need a 10mm socket, a phillips and a good pair of pliers and splicing gear. Remove the kick panel (screws along the bottom, on the door side and two by the brake release, also two push fasteners on top either side of the column - pop it out carefully, straight back), then remove the metal plate under that, then the plastic shroud around the column and ignition. Follow the stalk and you'll see the wires leading into the shaft. The wire on mine was broken right at the end of the stalk where it enters the shaft - completely separated so very easy to find. Poor design, each time you shift the lever you're flexing it and they break right at the point where they exit the hollow shaft. Fortunately on mine there was a 1/2" available sticking out so I simply spliced and protected.
I used part of a tiewrap tiewrapped to the shaft to hold the wire straight out of the lever, hopefully this fix will last longer than the car now. If it does break again it will break further out of the shaft due to the tiewraps.
Anyone else seeing this - good luck. It took me about 30 minutes but plan on an hour or more.
Old 07-05-2008, 09:35 PM
happyreefer happyreefer is offline
Vehicle: 94 F350 / 99 G-Caravan
I also Had the same problem on my 99 grand caravan w/ autostick (they do exist). I had my neighborhood tranny guy fix it for me.
Also had the dealer replace the clock spring. It was covered under a recall a couple years back.
__________________
1999 Dodge Grand Caravan 3.8L V-6 w/ auto stick, 85K miles
1994 F350 Crew Cab 7.3 IDI Turbo Diesel, 35" BFG Mud Terrains,6" Lift, All, ISSPRO gauges, Turbo Pressure, EGT's, Water Temp, Trans Temp, 190K miles
http://www.ford-trucks.com/forums/forum117/ name: happyreefer
Old 12-09-2008, 10:41 PM
Traveno Traveno is offline
Default Auto Stick Switch
I recently had some problems with our 99 grand caravan es with 83000 miles on it. It went into limp mode with the check engine light coming on. I used a code reader and received two codes. One for an incorrect 1st gear ratio and the second for transmission control failure. I took it to the dealership and they told me it was the auto stick switch($900) and that labor on it would be around $300. I only owe 1400 on it and am not willing to spend that kind of money on it. Is this problem similar to the ones you were having?? I just wanted to know if I could potentialy fix this or not.
Thanks!!!
Tags
1999, 1st, 2000, 99dodge, autostick, caravan, dodge, gear, grand, incorect, intrepid, problems, ratio, stick, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
