05 Caravan ABS and seatbelt
How do you disable the seatbelt dinger? I've tried over and over using the directions outlined in the owner manual, but am left with that annoying chime. Does anyone have the proper sequence to disable it?
Second, I just put new front brakes on, and resurfaced the rotors. Everything was smooth until the next day. After about 50 miles were put on the new brakes, the ABS light came on, which now disables the ABS. I've done dozens of brake jobs before, and never had a problem. I'm wondering what the deal is with this. It has only 32k on it as well.
RE: 05 Caravan ABS and seatbelt
do u have a scanner that is able to read the ABS computer?? if no then u will need to find some one that does and find out what the code is. Other then that there is no possable way of guessing what is wrong with the abs light. And as for asthe dinger the dealer as well can turn that off.
