97 caravan
RE: 97 caravan
Well, it's probably time to go back to the basics and see if you have fuel and spark. There is a shraeder valve on the fuel rail that looks like a tire valve. I would crank it for a few seconds and then carefully depress the valve to see if fuel squirts out--be carefull and have a rag ready. If you have fuel, then I would disconnect a plug wire and have someone crank it to see if you have a spark to ground. In fact to be safe, check for the spark first
RE: 97 caravan
I have 140,000 miles on the car. In great shape,but it has started to guzzle oil a bit.I intend to hold on to it for a while longer, would there be any point in switching to synthetic oil at this point? Would it harm the car? Or would it possibly address the oil issue? thanks
