DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 08-24-2007, 12:07 PM
WWIIGuy WWIIGuy is offline
Default Acceptable tire sizes for 99 Caravan
This may be a dumb question, but I have to replace at least one of my front tires and I want to know what tire sizes will work. I've got a couple 195/75 R14's on it now, one of which went flat. I have a couple 205/75 R14's sitting in the garage and I'm wondering if those would work just as well? I don't really want to spend $100 for new ones if I don't have to. Thanks for any knowledgeable advice that someone can give me
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-24-2007, 12:19 PM
haidangwa haidangwa is offline
Default RE: Acceptable tire sizes for 99 Caravan
Two sources I checked, Costco Tires and tires.com, show two different acceptable sizes. For 99 Caravan (Base), Costco shows 205/75R14 as the standard size. Tires.com shows 195/75R14 as the standard and also shows 205/70R14 as acceptable. If you go with Costco's source, then your tire size is spot on, but if you go with tires.com, then your 205/75R14 are 5mm taller than the 205/70R14 that they recommend. I say put them on and check that they don't rub around corners and bumps. Also, make sure thatboth tires on any axle arethe same size. You also need to make sure those other tires have the correct load index.
Old 08-24-2007, 12:58 PM
Thanks a lot for the helpful advice. You may have just saved me a bunch of money
Tags
205, 75, 99, caravan, dodge, r14, size, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
