99 caravan running lights issue
Old 04-22-2008, 01:12 PM
pcfuzion's Avatar
pcfuzion
pcfuzion is offline
Default 99 caravan running lights issue
I have a 99 caravan and neither the running lights or the lowbeams work anymore. It only works on hibeams..?? I checked all the fuses in the fuse box located under the hood but I just dont know what to try next...any help is welcome
I know the fuse box is different depending on the engine so mine is the 3.8L engine.
Old 04-24-2008, 07:41 PM
bvil's Avatar
bvil
bvil is offline
Default RE: 99 caravan running lights issue
Hmm let me try to think of some ideals for you. Personally I haven’t had too many problems with my electrical except for a fuse block once. I guess if it was me having the problem and I knew that my fuses were good and it was getting power to the fuse. I would then get a wiring schematic and check my switch, then fuse able links, low beam relay and or other relays located in that circuit and if all that was ok well then I probably check for broken and or ground wires.
If you don’t have a schematic then try these located at autozone they might help.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I think fig 10 is your low-high beam schematic at autozone.
This is the only ideals I have at the moment hopefully others might have some
(I admit mine sounds like a lot of work.) lol
Hope it helps
Quick Reply: 99 caravan running lights issue
