DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-05-2007, 08:18 PM
Papa Bear Papa Bear is offline
Default 95 Grand Caravan Help
I have hadmy 95 Grand Caravan (3.3L, 150K miles) in storage for the past 6 years while I was away. Now that I am back, I would like to use it again but it has a bad cylinder miss. I think I remember it had this when I first stored it. I replaced the plugs and wires but got no improvement. I learned the the bad cylinder is #3, back center. Next, I replaced the ignition coil, with still no improvement. Now, I am being told by my local parts man that if it isn't the plug/wire, or the ignition coil, it's probably a burnt valve (?).
When I talk to my local mechanic shop, they don't recommend partial engine repairs on a 150K motor and want to install a new reconditioned motor.
I believe I have used up all of my mechanical ability and don't know where to turn from here. I learned of the Dodge Forum when I wanted to know about changing the spark plugs as their locations are not obvious, so I thought I would try again for help. Thanks in advance for any comments, Papa Bear.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-06-2007, 11:47 PM
dishdude2k dishdude2k is offline
Vehicle: 2001 Dodge Ram 1500
Default RE: 95 Grand Caravan Help
first off.. 150k miles isnt all that much to require a new motor.. thats insane.. mine has 150 on it.. and all i need to do is re do the valve seals.. that is more than likely the issue.. put a little bit of 'marvel mystery oil' in the bad cylinder and see if that dont clear it up some.. a valve job isnt all that bad.. its not good.. but its probably all it needs and a hell of alot cheaper than puttin a whole new engine in it
__________________
01 Dodge Ram 1500 5.2 auto w/ 3 inch body lift and 3 inch suspension lift
99 Caravan 3.0
Old 09-07-2007, 11:35 AM
next2pool next2pool is offline
I would have the compression checked to see if it is a valve or mechanical issue. It could be sticking partially open as well or a bent pushrod. Sticking valves are pretty common after sitting for a while. Try that first before spending money or throwing parts at it.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
