DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-09-2007, 12:50 PM
shooter1 shooter1 is offline
Default rusty hitch mount bolts... help!
i want to put a Reese hitch on my 99 Caravanhowever the 4 mounting bolts turn very hard, like the top of the bolt is coated in rust and wont come down in to the threaded sleeve.
the first one i turnedtoomuch and the threaded sleeve popped loose, its just loose in its hole now
vice grips on the bolt head and a sawzall through the bolt?
then a hole saw in the side of theframe to extractthe rest of the bolt/sleeveand allow installation of a new nut ?
perhaps i should have used a torch to warm it all up first?i have three to go and would rather do it the right way for the rest of them...
i did spray some penetrant up there onto the bolt but it didnt help.
thanks in advance,
Wayne in Calgary
99 Caravan
86 900 Saab SPG notchback
87 900 SPG
91 900 2.1L NA
[/align]
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Caraman
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-09-2007, 01:34 PM
next2pool next2pool is offline
Default RE: rusty hitch mount bolts... help!
Yup--that's a real pita and a common problem. I recently put a hitch on mine and it came with replacement nuts that have a lever attached so you can snake them in thru a slot in the frame section. Luckily my Caravan is an AZ car so I didn't need them. I would try penetrating oil over the period of a few days and turn the bolts out and then back in a bit. Keep doing that and hopefully they will turn out a bit more each time. Don't just try to force them out without turning them back in a bit. If they do break off, I'm sure you can get those special nuts at most trailer hitch shops/
Old 09-11-2007, 11:21 AM
thanks for that advice - if i can get the new nuts as you say, i'll just break off the old ones, fish them out and use the lever'ed kind for attaching the hitch.
take care,
Wayne
[/align]
__________________
Caraman
Old 09-19-2007, 11:10 AM
i ended up having the hitch welded to the frame of the van - $100 and a hellof a lot easier than trying to get those bolts out and feed new ones in after having to take the bumper off...
Thanks again,
Wayne
[/align]
__________________
Caraman
Old 09-22-2007, 11:29 AM
by the way i was told that there is a shock system for the rear bumper and that undoing those 4 bolts effectively disconnects the shock system (however its also probably rusted to the frame inside) and so i'm glad i wasnt able to undo them! so that's another reason to just weld the hitch to the frame...
[/align]
__________________
Caraman
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
