Yes, yes & yes. The 99 engine came out the top (took the water pump out for little extra room,-it was tight. Going back in through the top - removed the crank pullry - had a world of room. The 1992 has alot more room taking the engine out through the top.
The electrical sensors (cam/oil press) between the 1992 & 1999 are the same except that the electral connectors are different - so they were swapped. Used the 1999 intake/plenum since the the 1999 fuel rack is different. The good news is that the van started as soon as the key was turned - like the engine was always there! Runs like a champ, just pssed NJ's two year motor vecicle inspection including running on their threadmill.
