No headlights please help 97 caravan
Hi i have no headlights i have changed everything-- headlight switch,relays,fuses,body control module,signal switch,.i have notice i have no power in my fuses under hood for my high and low beam 2- 10 amps and 2 -15 amps o and i changed fuse panel under the hood also..any help would be greatful thanks..
RE: No headlights please help 97 caravan
have you checked the bulbs In know that sounds silly but sometimes they can burn out at the same time, if not I would start checking the voltage from the battery onto the lightsandtrace the circuit from the battery to the headlights and the spot where you have voltage and there isn't is where the problem is, I'm sorry I can't offer specifics but that the old fashioned way to do it
here are link for wiring diagram maybe it can help you.
with drl:http://rapidshare.com/files/64393509...w_drl.pdf.html
with out drl:http://rapidshare.com/files/64394360...o_drl.pdf.html
