speaker replacement
RE: speaker replacement
vlmuke is correct about the size. However not all 5 1/4"s will fit. Go to Crutchfield and use the car selector and you will find which ones are a drop in fit. The wiring may not be there in the door if you plan to install in the front door speakers. The rear and dash should have speakers and wiring already installed. Of course if your willing to cut sheet metal etc you can make some of them fit.
