RE: missing dust cap on front wheels
my 2000 caravan dosn't have one either. Because the Caravan is front wheel drive, it uses a Hub assembly that contains the bearing. the axle passes through the hub but carries no weight. The Hub is completely sealed, and the nut only holds the axle in the hub, so it doesn't require a dust cap.
Tim1234
