RE: 20 years and 386,081 miles
There is an Idle Air Control valve in the throttle body that might be dirty.This can cause the high idle and can be fixed by you.(maybe)
Get some spray carb cleaner and remove the intake tube between the air filter and the throttle body.There will be a little hole in the bottom of the T/B just in front of the throttle blade.Start the engine and spray the carb cleaner into the little hole.You should get the engine to stumble and kick but this is good.That means the cleaner is getting into the engine and past the dirt in the IAC.
Another possibility is the existence of an intake leak,and now that I think about it,with the amount of miles and the progressive nature of your problem,this is more likely.You can use carb cleaner to find the general location of the leak by spraying around the intake system and listening for the engine speed to change.
A disconnected,cracked,or leaking vacuum hose is the most likely culprit.
__________________
92 Dodge Caravan 3.3 07 TC 3.8, 04 Mustang GT three Harleys and an airplane.Buy American!!!
