DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-04-2007, 09:38 PM
vlmuke vlmuke is offline
Default off topic sorta I have a neon with a moonroof
I just bought a 97 dodge neon I know this is the caravan section but haven't got any responce from the neon board and there is a lot of excellent people on this board any way
I just bought a 97 neon with a power moonroof I don't know if it factory or not but its missing a switch and when I put a jumper wire from the hot to the two ground wire it sparks and blows the fuse anyone ever fix one before can you get replacement parts for them ect... any suggestions would be helpful
Thanks
Rich
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-05-2007, 10:57 AM
dishdude2k dishdude2k is offline
Vehicle: 2001 Dodge Ram 1500
Default RE: off topic sorta I have a neon with a moonroof
well.. any time you put a wire from hot to ground.. your going to blow a fuse.. its a givin.. thats what a fuse is designed to do.. you need to check all the wiring on it. and know what wires yoru toutching together.. my guess is.. the switch is gone.. because it doesnt work..
__________________
01 Dodge Ram 1500 5.2 auto w/ 3 inch body lift and 3 inch suspension lift
99 Caravan 3.0
Old 12-05-2007, 04:07 PM
I figured that was probably why the switch was missing I figured it has one plug with three wires going to it 2 blacks and a red the red is hot and I assumed the other two actuated the window but like you said its a dead short so I am stumped at this point
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Old 12-06-2007, 09:11 AM
could be the motor for it.. if its shot.. and shot bad enough.. i guess it could be dead grounded out... only way there should be a 'ground' on any of these 3 wires.. is if there is a light in the switch.. but if there is no light.. you should have power.. and when you push the switch one way it will connect power to one wire.. and vice versa... i would get a ohm meter and check to see if any of those are grounded
__________________
99 Caravan 3.0
Old 12-06-2007, 01:40 PM
the dome light is behind the moonroof the switch is missing all that is there is a hole that I can pull the connector out of
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
