12-29-2007, 06:18 PM
2001 Caravan wipers, radio, windows, blower all non-operational. Help.
This ad is not displayed to registered and logged-in members.
Register your
free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
12-30-2007, 09:44 AM
RE: 2001 Caravan wipers, radio, windows, blower all non-operational. Help.
Have you checked all the fuses? Is your ABS light on? I had a similar issue. All my fuses were okay. Ended up being the clock spring.
12-30-2007, 01:58 PM
The ABS light isnot on. I can't find any interior fuses, I read that it may be related to the Body Control Module.
01-03-2008, 01:11 AM
Vehicle: Mits P/U , Dodge avenger(1996) .
Did you ck the IOD fuse in the PDC box?
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
01-14-2008, 08:37 PM
I had a situation a few months ago where my climate controls were inoperable.
It turned out to be the control head. Had it replaced with a boneyard piece and everything works now.
My symptoms were tremendous heat blowing out during the summer and a thunking noise behind the dash.
HTH
01-15-2008, 12:14 AM
i would lean more toward the BCM that is located under the dash on the driver's side.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
