DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-30-2007, 01:06 PM
pugle pugle is offline
Default 1994 Grand Caravan DRL Problem
Hi, I have a '94 Grand Caravan (3.3L V-6) with 545,000 km on it. On Friday, the DRL's would not shut off when the engine was turned off. I've tried removing fuses, and looking for stuck relays... no luck. The only way to get the lights to turn off is to disconnect the ground cable from the battery.It's just the DRL's... all the other lights are off as they should be. The headlight switch has no effect either. When the switch is turned on, all the lights work as they should and shut off as they should.Any ideas that could help me out? Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-30-2007, 02:29 PM
Whacked Whacked is offline
Default RE: 1994 Grand Caravan DRL Problem
Had a 93 with the same problem. It's the DRL module on the passenger side firewall. It's square and it's black.
Old 12-30-2007, 02:34 PM
Thanks Whacked, I'll Take a look and see. I might be able to get one from a scrap yard or something. The van is going to the junk heap in the spring, so I don't want to spend a lot on it now. But I must admit... it's served me quite well over the years. This is just one of those annoying little problems that pop up from time to time.
All the best.
Old 12-30-2007, 02:47 PM
Hi Whacked, I un-plugged the module and the DRL's went out. The light system works normally otherwise. So now it's just a matter of seeing if I can find a cheap replacement.
Thanks again for your help.
Cheers!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
