fuses blowing help
Old 01-16-2008, 07:53 AM
nvrplay2ty's Avatar
nvrplay2ty
nvrplay2ty is offline
Default fuses blowing help
Hello eeveryone, a newbie here and I hope somebody has an answer. i have a 1996 dode caravan, 4cyl, auto trans. While cruising at low speeds and a slight acceleration It skips just a little bit, its annoying but goes away if you step on it... I could live with that NOW 3 times in the last 100 miles, the 25amp motor fuse has blown. all 3 times its when accelerating. i replace the fuse and its fine for a little while. The computer shows no error codes, could it all be the coil pack? any info will be appreciated.
thanks
Brad
nvrplay2ty@yahoo.com
Quick Reply: fuses blowing help
