DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-24-2008, 01:22 AM
97ektwlqos 97ektwlqos is offline
Default using silicone on trany pan or not
hi! all
this is second post ( did first one on ram van )
this site is great i am happy to have login name and pw
ok i changed atf for 99 gc 3.3l around 4 month ago, (first time by myself ,did mistakes as beginner or amateur like overfill or handling silicone for trany pan)
and 2 weeks ago trany was licking a lot so i change gasket ( not filter) , add 4.5 qt ( i think proper amount for my trany).
to be surprised, it is licking again today.
i did again today. this time is differrent, i use chilton repair book, it say using silicone (sealant, whatever..) on trany pan when install
i think that is problem this time i use only gasket
putting silicone ( sealant)on pan make just mess on pan and my hand
it is not licking ( i'm not on road yet)
i hope not and i hope my decision save money ( next time same thing happen i'will take it to expert guy)
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-26-2008, 01:23 AM
vlmuke vlmuke is offline
Default RE: using silicone on trany pan or not
I personally try to avoid using silicone try torquing the bolts to spec and see if that helps
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Old 02-27-2008, 02:08 AM
TJeepman TJeepman is offline
Using silicone is standard practice, it seems, for the transmission pan.
Perhaps your solenoid pack is leaking - not an uncommon problem.
__________________
If it ain't broke, don't fix it.
Old 02-28-2008, 12:31 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Here are some mopar part numbers for the reuseable pan gaskets.
5011113aa 31th
5011114aa 42le
5011115aa 41te
Thats if you don't want to use silicone. Always clean out the bolt holes if you are using silicone. Or you could crack the case.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 02-28-2008, 12:39 AM
onephatcracka onephatcracka is offline
after using RTV a typical place for it to leak is at the back of the pat toward the diff. the reason is the diff still holds fluid and will continue to drip even though you wipe it off. a trick to do is to make sure the metal as NO atf on it. i usually blow shop air into the diff portion to blow the fluid out. i've also seen guys use a small piece of brake line that is curved in a candy cane shape to alow gravity to siphon the fluid out. hope that helps
Old 02-28-2008, 04:00 AM
thank guys for your input
so far no leaks
but i can not guaranteed for long trip
i know mopar reusable gasket but it is around $60
next time i better try that one
Old 02-28-2008, 11:52 PM
deezozdodge deezozdodge is offline
It depends on the trany pan's gasket, on whether to use silicon sealant on gasket. Some gaskets arefabricated and some are a rubber material. If you are using the one that is rubber material, do not use silicon sealant on it; instead, use a thin layerof trany fluid (just like as you would do with an oil filter - putting a thin coat of oil around the seal).
__________________
Darryl Waddy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
