DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-25-2008, 11:03 AM
kriscot kriscot is offline
Default 08 Grand Caravan sliding doors
Is anybody else having any issues with the power sliding doors..primarily driver side not shutting? There appears to be no rhyme or reason as to when it happens. The door will get to about 80-85% closed and then reverse itself. a couple of times my door as been left open sitting in a parking lot because I assumed it shut like it was supposed to. Any information or guidance would be greatly appreciated. I have not called the dealer yet, I wanted some input from other owners before I let them start messing with my doors. Thanks!
Scott
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-26-2008, 12:30 AM
dishdude2k dishdude2k is offline
Vehicle: 2001 Dodge Ram 1500
Default RE: 08 Grand Caravan sliding doors
make sure there is nothing lodged into the track of this thing... and it is totally clear.. (by where the chain is on the bottom)these things have a sensor that will sense resistance.. like if a childs fingers were caught in there. the door would re-open.. this sounds like what its doing.. they might need greased up to help it along..
__________________
01 Dodge Ram 1500 5.2 auto w/ 3 inch body lift and 3 inch suspension lift
99 Caravan 3.0
Old 02-28-2008, 12:32 AM
onephatcracka onephatcracka is offline
that or else the track wiring. they still haven't changed the design of those and they still go bad.
Old 03-25-2008, 01:34 AM
tazman444 tazman444 is offline
There is no track chain on these sliding doors, just a schlepp cable and in some models guide cables. It sounds like the schlepp cable has become crimped and the plastic casing has broken, causing it to bind. Check the cable and if that isthe case ask the dealer to replce it with an updated schlepp cable. Also give the new cable a half-turn inboard prior to connecting it. This will cause the wire to stay tucked into the channel below the scuff plate better.
Old 03-28-2008, 12:22 PM
cableguyx2002 cableguyx2002 is offline
Our 2008 Carivan was doing the same thing with the door not closing 50% of the time. I took it back to the dealer for service and they said it is a software glitch. They reprogramed the computer and the problem is cured. Its been 2 weeks and it hasnt happend again. Hope it works for you too.
__________________
Brian
Tags
cable, caravan, door, grand, power, schlepp, sliding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
