RE: 99 gc window motor replacement
I changed the motor on my 01 it was very easy but the thing is that the cables get moisture and bind up I would suggest changing the whole assembly, but if you want to change the motor its just four bolts holding it onto the regulator if am correct they are phillips head but might be torx
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
