DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 02-28-2008, 05:21 PM
jaboerner jaboerner is offline
Default Trans Codes Question.
I just got this 1998 Dodge Grand Caravan 2 days ago. The people i got it from said the transmission was replaced in Sept. 2006. It has about 20,000 miles on it now. Well i was driving and the transmission did not want to shift out of gear. It does not do it all the time, just sometimes. I took it to my auto parts store and the ran a test on it. The codes that came out was P0715, P0731, and two for P0700. They could not tell me what they ment so i went to the dealership and they told me that they are Trans Codes. I was wondering if anyone can tell me what might be wrong with it? And about how much it might cost to fix. The dealership wanted to charge me $85 just to figure out what it is. I am trying to Save some money and hoping i can get some help from here. Also the service soon light did go back off. Any Help would be greatly appreciated.
Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Andy Boerner
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-29-2008, 09:58 AM
floorslayer1 floorslayer1 is offline
Default RE: Trans Codes Question.
700 is general transmission fault code
715 is input speed sensor
731 is gear ratio
If your chek engine light isn't on, that is probably good and that they are just stored codes from prior things. If Light is on, you probably need to change the speed sensor. If that does not solve it then you might night a re-flash of the TCM ("Quick-Learn") and that should clear up the shifting. The Speed sensor might be setting off the "gear-ratio" fault and that is why that might fix the whole thing. p0700sets itself usually prior to any other TCM faults, just to let you know something is going on. Good Luck
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Old 02-29-2008, 11:36 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Replace the input sensor and clear your code. When one the two sensor goes dead meaning the tcm controller see zero rpm, then the trans goes into limp in. That is why you have a gear ratio error too.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 03-01-2008, 08:05 PM
richardh05k richardh05k is offline
I had this same thing happen on my 98 GC.
I had the Trans. replaced and then in about 20K the light came on. I discovered when I pulled the old sensor it was a mag pickup and there were metal filings attached to it. I went ahead and replaced the sensor but I think if a person were to clean off the sensor it would be fine.
In any case the codes and problems went away as perscribed by the all knowing Master tech.
Tags
2000, 715, code, dakota, dodge, durango, input, learn, p0715, quick, sensor, speed, sprinter, stratus, tcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
