RE: 95 Caravan Transmission Bearing
You could have a dirty ais motor, egr and maybe a vaccum leak. Back to the trans. are the axle seal leaking? If they are leaking, then the side bearing and cups will need to be replaced. The diff in the 3 speed vs 4 speed, on the 3 speed when the side bearing go bad the metal goes to the govneror and causes the valve to stick. meaningno up shift or down shift. but the 4 speed does not have a govneror but does have a solenoid pack.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
