DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-04-2008, 09:27 PM
CEN CEN is offline
Default 2002 Dodge Grand Caravan - the AC will only run on the high fan.
What part do I need and can I replace it myself? If yes to question 2, how?
Many thanks!
Eddie
P.S. This will be the second time this has happened to this van. It happened to our 1996 also. Is this a common problem with Dodge vans? Is there something electrical going on if this died and the cruise control died also? Both died last time around the same time as well. Any ideas?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-05-2008, 12:52 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Default RE: 2002 Dodge Grand Caravan - the AC will only run on the high fan.
Are you saying you only have fan speed on high? Resisitor........ under glove box. And the speed control, Is the air bag lite on and does the horn blow too. If the air bag lite on horn doesn't blow, good chance the clockspring is shorted out causing the speed control to stop working. 1996 van has a lifetime clockspring warranty.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 03-05-2008, 09:02 AM
vlmuke vlmuke is offline
do you mean 96 on has a lifetime clockspring warranty? as my 01 does the same thing intermittenly
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Old 03-05-2008, 11:48 PM
Yes it does. 1996 thru 2000. are lifetime warranty.
__________________
Old 03-22-2008, 02:35 PM
raybnlv raybnlv is offline
I too have this problem with my 2002 Grand Caravan where air only blows out when set to high. Can you please elaborate as specifically as possible where I need to locate the resistors that need to be replaced? From the previous post, I understand that I need to locate this under the glove box. What does it look like? Also, where can I find the resistor to replace for the rear A/C unit? Thanks.
Old 03-26-2008, 12:46 AM
Intrelude Intrelude is offline
http://autorepair.about.com/library/a/1i/bl743i.htm
I had the same problem, called the dealer, asked for a "Caravan Blower Motor Resistor". Apparently, it's a common issue. It only took me about 5 minutes to replace. Now I am able to change fan speeds... for the front. The rear A/C still only blows on high. :-( Also what I noticed is it takes forever for it to blow hot air. I have to play around with the power on/off button until it kicks in even after the engine is warm already.
Tags
ac, caravan, dodge, high, runs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
