DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-10-2008, 07:42 PM
PatVan PatVan is offline
Default Headlight assistance please
Hoping someone can help. I have a 2002 Grand caravan. Both front headlights work either running or highbeam, but theright one does not when you turn the normal lights on. I have changed the bulb and no resolution. I even checked the spare bulb on the other side and the original and they both work fine. Any suggestions on what to check next? Any help is greatly appreciated! Thank you in advance.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-10-2008, 10:17 PM
vlmuke vlmuke is offline
Default RE: Headlight assistance please
someone else posted the question a couple of days ago there is a module that either needs to be reset or replaced I believe the solution was to unhook the bettery for 15 minutes to reset the module
__________________
51 Studebaker M35A2
01 Caravan
97 Neon
Old 03-10-2008, 11:22 PM
Parts/Service's Avatar
Parts/Service Parts/Service is offline
Vehicle: 1993 Ford Mustang LX 5.3
You have a problem with the front control module or the integrated power module. #1 in the pic below is the front control module. Try unpluging it and make sure that there is no grime in the terminals. We had a van with this same problem a few weeks ago and the integrated power module(fusebox) was bad. But I had another van with this same problem and the front control module was bad. No real good way to tell which is bad....You can also reset the modules by unhooking BOTH battery cables, wait 5 minutes and then touch the battery cables together for a few seconds(make sure they are NOT hooked to the battery). The van may run like crap for a few minutes after you hook it all back up until the pcm relearns its parameters....Call me if you are unsure of these directions.....DAVID
__________________
Starting my 11th year as a Parts and Master Certified Service Manager. James O'Neal Dodge. Bremen GA.- 1-800-663-2522 www.onealdodge.com www.bigostreetrods.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
