DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-11-2008, 04:58 PM
corncob corncob is offline
Vehicle: 1997 Dodge Grand Caravan
Default Rear main leaks on 1997 caravan
I have a 1997 Dodge Caravan with 149000 miles on a 3.0 engine. The rear seal is leaking about one qt in 1000 miles. I'm using 10w30 oil. Should I go to 40w oil?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-12-2008, 11:32 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Default RE: Rear main leaks on 1997 caravan
You may want to remove the trans and replace the rear main seal. It is a one piece seal.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 03-27-2008, 11:00 PM
pxl1835 pxl1835 is offline
I have a 1997 3.0 van with 180000 miles as well, it also leaks somewhere, butI don't know where it leaks yet. Anyway, I just took a auto class not long ago and was taught that for older cars like mine and yours, the thicker grade should be used because there are more rooms between the parts inside the cylinders. So 10w40 is the way to go.I used 10w30 last summer, this winterI am using 5w30.I will try to use 10w30 in winter and 10w40 in summer whenI can. Good luckswitching the grade.
__________________
1997 Dodge Grand Caravan 3.0L 6 cyl 200,000 miles
Old 03-28-2008, 10:54 PM
One thing to add: if you are using conventional motor oil, keep on using conventionals. if you are using synthetic oil, then keep on using
synthetics. Switching from conventionals to synthetics or the other way around on high mileage cars could break down the car because your car at such an age is already used to the type of oil being used. So the bottom line is switching grade in the same type of oils.
Good luck switching grades.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
