DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 03-14-2008, 09:57 AM
jlziegler98 jlziegler98 is offline
Default Brake scraping
Hi everyone. I have a 2006 Dodge Caravan (about 25,000 miles) and here is the problem. A week ago I took it to a small shop for the yearly inspection. Everything was fine when I dropped it off.I picked it up after getting a clean bill of health from the mechanic. On the way home I heard some troubling noises. First there wasticking sound coming from the front left wheel and the rear right wheels. These are the wheels the mechanic supposedly pulled. The ticking sound sounds almost like what you'd expect when the hubcap isn't fitting right and it is popping against the tire. Anyway, thats not all. Next the brake pedal is pulsing when you apply the brakes. When you do apply the brakes you also hear a scaping noise, kind of what you hear when the pads need replaced. This sound iscoming from the same two wheel mentioned above. My thought is that if I did need brake pads and shoes, wouldn't that have been picked up at inspection time? Supposing the mechanic didn't really pull the wheels (just put on the sticker, which is not out of the realm of possibility) doesn't the timing seem coincedental. What are people's thoughts on what could be wrong with my van. I have two 15 month old twin daughters and I want to be sure the vehicle is safe. Thanks for your help.
Jeff
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-18-2008, 01:00 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Default RE: Brake scraping
I would either go to other shop or pull the wheels off and ck them. If the brakes are grinding into the rotors, take picture with dates on them. Then go back to the shop that put the sticker on the van, and have the shop replace the brakes at no charge or you will take them to the B.A.R. Which in turn if they go out to the shop, the owner could end up paiding very large fine.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
