Go Back   DodgeForum.com > Dodge Vans & CUVs > Dodge Caravan
Sign in using an external account
Register Forgot Password?
Sponsored by Dodgetruckparts
Click Here
why is the sliding door lock not working automatically anymore? 05 caravan
Thread Tools Search this Thread
  #41
Old 06-10-2013, 09:00 PM
Caravanor Caravanor is offline
Vehicle: 2003 Dodge Caravan Sport
myGC: Thank you for the detailed and prompt reply! I understand.
However I'm confused as to which side door (left or right) is missing the hole to reach the torx screw, as I thought I had read it was the right (passenger) side that was missing the torx screw hole. Maybe it varies from from year. Might it also be possible to use a sheet metal cutter or snips to cut a slot up to where the hole should be?
As for the Dorman actuator, yes I've seen mostly negative reviews on Amazon. However 1aauto.com just told me they have sold 545 of these and no returns; I don't know over what time period. They said they use various manufacturers, currently Dorman. Their part # is
1ADLA00087 which should be the Dorman 746-259.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2003 Caravan Sport - 3.3 L
98,000 Mi (157,000 Km)
  #42
Old 06-11-2013, 03:42 PM
myGC myGC is offline
Default Passenger door needed to be drilled
My Passenger door was missing the hole for the screw, i can't speak on the drivers side, haven't had to work on that one yet!
If yours doesn't need to be drilled, great!!! That's the way it SHOULD be.
If you do need to drill. I would suggest a drill. If you use snips you'll need to cut, and the warping action of snips will leave it looking like garbage. (yes i know it's hidden)
The drill is a nice clean hole. I spray painted the hole after removing it so that the metal didn't rust. If i would have used matching paint, someone might think it was a factory hole.
I'm sure you could cut a slot to the screw and it will work, but it won't be a job you'll be proud of.
if you do drill, take a center punch(or a nail) and line it up with the shiny screw. hit the nail with a hammer to make a very small dent in the metal. that will make it so your drill doesn't "walk" while starting to drill, especially if you don't have a good metal drill bit.
As for the doorman parts, I've had other stuff from doorman, and so far they have always done the job. I guess I don't have too good of a reason for not saving the $30 and going with them this time.
  #43
Old 10-06-2014, 07:29 PM
Mocsnlinsa Mocsnlinsa is offline
My driver side is stuck closed, the locks work, but it will not open.
I think it has to do with the gas door which was stuck for short period of time in the open position......any advice. Thank you
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
