Just replace front sway bar links and bracket bushings. Front end sounds way better. spent about $75 at autozone on both links and bushings.
Now the questions is where to get the rear sway bar bushings. Autozone was unable to find them on there super computer. I havnt gone anywhere else yet but thought I would give the forum a try.
Also tried the search portion of this forum with no luck.
Gary
1999 Dodge Grand Caravan
3.8 L V-6
80K miles
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Grand Caravan 3.8L V-6 w/ auto stick, 85K miles
1994 F350 Crew Cab 7.3 IDI Turbo Diesel, 35" BFG Mud Terrains,6" Lift, All, ISSPRO gauges, Turbo Pressure, EGT's, Water Temp, Trans Temp, 190K miles http://www.ford-trucks.com/forums/forum117/ name: happyreefer
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Thanks for the link to the "sway bar links". I also need the bracket bushings. Do you happen to know where to get the bracket bushings as well? the two that attach to the rear of the axle.
__________________
Thanks for the reply again, This is the first time using this forum for my wife van. Thanks so much for the help. I tried that mopar site and could not find it. Thanks again.
__________________
Parts came in, Replaced Rear Links and rear bracket bushings, Turns out this was not the noise I was hearing.
What I was hearing was a loose shock. the rear passenger side bolt was loose on bottom of the shock. Tightened her back up and drives and sound new again.
__________________
