RE: 96 Grand Caravan LE...Acceleration problem
For a moment there when I checked the wiring, 2 of the numbered wires didn't follow the firing order, but it turned out it was right they just used the wrong numbered wire for that cylinder.
I tried the key on & off ,etc to check any codes and I discovered a code 43 that can be narrowed down but basicly its a misfiring on a cylinder or cylinders....can that be I have a bad cylinder or can I still have a problem that can actually be fix without a rebuild?
