DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 05-17-2008, 11:16 AM
floorslayer1 floorslayer1 is offline
Default 99 GC rear brake gravity bleed
Hi, I'm going to do the rear brakes on my 99 GC (once I get the drums off). I Know that one of the wheel cylinders is going bad and I'll have to replace it. Due to upstate NY corrosion I'm afraid I will be in for a brake line replacement because I'll probably have ttrouble getting the brake line fitting to come loose without damaging either the line or fitting. I'm not as familiar with ABS sytems as I'd like to be and am concerned about bleeding the rears of air after putting the new cylinders on. I've had very good luck gravity bleeding front brakes on this generation, but have never done rears with ABS.
My question is will the rears gravity bleed or will the ABS system not allow this generation to gravity bleed? (I'm a one man show, hence the need for gravity bleeding).
Second question is anyone have a super trick for getting the drums off (again upstate NY corrosion and the ever present wear ridge in the drum)? I'm putting new drums on so I'm not overly concerned with saving the old drums.
Thanks for any help available.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-23-2008, 12:22 PM
Default RE: 99 GC rear brake gravity bleed
Rain has delayed me til this weekend....still hoping for a little input before I start. thanks
__________________
Old 05-25-2008, 10:58 PM
Gravity bleeding worked fine... Let it drip for around an hour and had little to no air when I presssure bled them with the help of a friend.
Brake lines were as bad as I thought although What I ended up doing was holding the fitting going into the brake cylinder(with vice grips)and unscrewing the brake cylinders from the lines after I had freed them from the backing plate. Then I just threaded the new wheel cylinders on the lines and reattached them to the backing plates.
Had to beat like Heck on the old wheel bearing to free it up to replace it, but got that done.
Drums, Wheel Cylinders, New Shoes, Brake Spring kit, wheel Bearing assembly $265.00
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
