I am new to the forum and am glad to have found a forum with great help.
I have a 2005 dodge caravan and the interior light over the back seats will not work. I have checked the bulb and ground all good, but no power. Checked for fuses under hood no luck. checked the dash dimmer switch but wire color does not match. This is where the light was controlled from when it worked.Checked the map lights wire color but not the same. Has anyone had this problem or know where I can check next.
I am grateful for any help.
Revgross96
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Problem Solved I was reading from http://www.dodgeforum.com/m_1198564/tm.htmand pulled the IOD fuse just to double check, it was fine but when I put it back now the light is working fine. Must have reset a relay somewhere.
