RE: Replaced front rotors and pads on 2006 Grand Caravan
Could be the shift interlock solenoid in the steering column. That's what prevents you from shifting out of park unless your foot is on the brake. Try disconnecting the electrical connector to the brake switch and see if the noise goes away. If it does, you've probably nailed the source of the noise.
__________________
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. Visit my blog for over 400 fix-t article, tech tips, TSB's, and wiring diagrams: www.ricksfreeautorepairadvice.com
