2002 Caravan Intake Manifold Gasket Leak. Please help with suggestions / recommendations !
I saw some coolant leak on the driver side. I looked under hood and found coolant traces on the engine. I checked under the vehicle and saw some couple of droplets of coolant near the intake manifold gasket. This coolant leak appears on and off. When it occurs its only a few drops.
My mechanic says that intake manifold gasket has to be replaced. Sometimes it may prevent a leak and at other times collant drops down on the exterior and on the ground. He is looking at charging close to $700 ($500 labour + $200 parts/supplies).
My questions is:-
1. Is $700 right prices for replacing Intake Manifold Gasket on Dodge caravan ?
2. Can I just continue running my vehicle with the coolant leak, adding more coOlant on a monthly basis ? Will this case any engine damage or blow any other system in my vehicle ?
Any suggestions / recommendatiosn will be greatly appreciated!!!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
