DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-07-2008, 01:15 AM
kdowg65 kdowg65 is offline
Default How to replace sway bar bushings
My 1997 Grand Caravan is making some noise when I go over bumps etc and with 153k I think replacing the sway bar bushings would be a good start. I got the bushings and want to know the best way to replace them. If after replacing them it still makes noise, I then will replace the links and then the struts if needed.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1997 Dodge Grand Caravan 3.0 L 153k
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-07-2008, 03:33 PM
Default RE: How to replace sway bar bushings
Did some checking around and found AutoZone has real good info for DIY.
http://www.autozone.com/shopping/rep...00c1528003c800
__________________
Old 06-07-2008, 08:43 PM
RickMN RickMN is offline
Text and photos of the sway bar bushings and end link replacment: Caravan Sway Bar
__________________
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. Visit my blog for over 400 fix-t article, tech tips, TSB's, and wiring diagrams: www.ricksfreeautorepairadvice.com
Old 06-13-2008, 02:21 AM
happyreefer happyreefer is offline
Vehicle: 94 F350 / 99 G-Caravan
remember when working with a sway bar both tires need to be the same. either both on the ground or both off the ground.
Very easy job, just did all sway bar links front and rear on my 99 GC. Electric Impacts makes the job 50% faster.
__________________
1999 Dodge Grand Caravan 3.8L V-6 w/ auto stick, 85K miles
1994 F350 Crew Cab 7.3 IDI Turbo Diesel, 35" BFG Mud Terrains,6" Lift, All, ISSPRO gauges, Turbo Pressure, EGT's, Water Temp, Trans Temp, 190K miles
http://www.ford-trucks.com/forums/forum117/ name: happyreefer
Tags
1999, 2000, 2008, arm, avenger, bar, bushing, bushings, caliber, caravan, dodge, grand, link, replace, replacing, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
