Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
How can you use an air impact on a pulley where its almost impossible to get your hand into?
You need to loosen the bolts before you remove the belts, and then some times jam the pulley without bending it. Good luck with that.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Its a lot easyer to do the job. and that way you know when you start the engine it will run and not guessing if you set the belt up right. Also if you don't the timing belt right you bend valves!!!!
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
