I intend to replace the water pump and timing belt for 97 dodge caravan 3 ltr engine any body can provide me with the detailed instructions, and how to lift the engine to remove the engine mount.
thanks
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
There is not much to tell, remove the front motor mount and raise the front of the motor. Be sure to set your timing marks before removing the timing belt. There will be a bracket bolted to the pump, remove the bolt going to he pump and bend the bracket so the pump can be removed.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Crankshaft pulley, move the p/s and remove the a/c bracket.
__________________
__________________
