DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 08-11-2008, 05:54 AM
simonlimon simonlimon is offline
Junior Member
Default transmission help
Hi there, im new to the site and new to dodge cars as well, any way a friend of mine gave me a 98 caravan se, he said the only thing wrong with it was th tranny. first thing I cheked was the plug that connects to the Transmissin Solenoid Pack and there is no electric current flowing through any of the wires. My question is, witch color wire sends power to the TSP?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-11-2008, 11:11 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Are they using a DRB3? I need you to post the codes that you have. You maybe loosing battery switch voltage. Causing the trans to go into limp in.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 08-12-2008, 11:28 PM
Junior Member
Well i finaly got it scanned, the scanner said; P1495 pcm fault,no ccd message from TCM. Does that mean the tcm went bad?
Old 08-12-2008, 11:50 PM
khooper khooper is offline
I think your going to need to start with a basic voltage meter..Check all your Solenoids and find out which one is out of specs.
______________________
Great Dodge oem parts
Old 08-13-2008, 12:28 AM
Junior Member
i was kinda hoping it was the TCM that went bad, since theyr so easy to find at the local junk yards
Old 08-13-2008, 02:16 PM
Junior Member
What does code P1495 actualy mean?
Old 08-13-2008, 11:28 PM
LDP leak detection solenoid circuit, could be a large leak on the evap system. If you have a ccd message, does the cluster have all the shift indictor lites up? And does the engine start and run? The reason i ask is the bus curcuit maybe down, I have seen the ignition switch maybe causing all your problems.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
