2008 Caravan: Front Heat/AC Blower Intermittent/not staying on, Rear OK
My 2008 Caravan just went out of warranty so I am trying to research this issue ahead of time.
My Front AC/Heat Blower is failing to come on, while the rear blower is running just fine. I turned the vehicle off, and the blower started running for a minute and then stopped. It went off and on a couple times and stayed off. I killed the engine and waited, restarted the engine and it came on again, then went off shortly after. I tried searching related threads, but they appear for older models. Some of those links are here:
The problem could be in the WIN module, ( wireless ignition node). Are you also loosing radio or wipers too? A new win module should fix this problem and maybe covered under your emission warranty, call your local dealer and find out.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
