I'm not sure what kind of info you're looking for, but the sway bar links and bushings are a common problem. The links are behind each wheel and look like a small straight bar (approx 10 - 12" long) mounted vertically. The bushings are further under the vehicle and little harder to describe, but are more likely to be the main cause of your noise. You may get some one to rock the vehicle while you look for your noise to make sure exactly the problem.
