DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 12-29-2008, 09:07 PM
Version3 Version3 is offline
Default 2001 Caravan w/ Transmission Issues
Well, I know little about these, and not much about Automatics in general, but I can understand a few things, and like MANY people I'm on a super tight budget (so I have to do what I can here, with what I have if possible at all). Our only car (the previously mentioned '01 Caravan) gave me some trouble the other morning that went south quickly.
I was driving normal, made a right turn and pressed the gas to find it rev'ing as if in neutral. Some light feather of the gas pedal, and I got it to engage, but clearly it was giving me 2nd gear only. I would speed up some and it would slip, then back down to feathering and so on. This continued as I limped the van home where it seems to have given up. Later that day, and the next day it wouldn't go into a gear at all.
I waited a few days, and started the van. With a bit of feathering it engaged, but I got a whining noise along withy my crippled feeling reverse. It wanted to move the van, just not with a fully engaged feeling. I maneuvered it around the driveway a bit using reverse and drive with this same kind of feather to engage, non-committed gear experience. All the while the whine noise continued. I shifted into park, and the noise still continued. It continued until I shut it off about 20 seconds later. Starting it back up, gave me a somewhat normal sounding engine. Engaging it, the whine came back. I could smell it (smelled like clutches or torque converter or something) and a bit of whitish smoke was in the air around the van (it was kinda dark though).
I've looked at the fluid, and it still appears red in color. Smells a little, but not what I've smelled as "burnt" in the past (I had to put my nose on top of it to smell it). In park (and cold) it measures a little high on the dipstick (in the hot range), and it still behaves as before.
I'd like some information on where I can start basic diagnosis here in the driveway, and what the likely scenarios are on it. Basically, is it worth fixing it? It's a semi-beat down base model Caravan, with a few other issues... so a $3K transmission is not an option for it's future.
Thanks in Advance!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-02-2009, 05:54 PM
chopper chopper is offline
This sounds like the tranny's dying.Not going into gear hot is surely a very bad sign.The fluid doesn't have to smell burnt or even be discolored.
You might go to a shop that actually rebuilds dead transmissions instead of replacing them with one from a rebuild factory.This is because you are only paying for the parts that need to be replaced instead of a whole new (rebuilt) transmission.This is only true IF you get a reputable shop.Ask around and see what you can find out about local shops.
__________________
92 Dodge Caravan 3.3 07 TC 3.8, 04 Mustang GT three Harleys and an airplane.Buy American!!!
Old 01-03-2009, 12:14 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
You could have the same problem I have seen in the past 4 weeks. I had 4 transmissions with no reverse and loss forward gears. The fluid was red and not burnt. All 4 transmissions had snapped off the rear planetary gear set. This could be the problem you are having.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Tags
01, 2001, automatic, bit, burnt, caravan, dodge, engage, forwaed, gear, planetary, reverse, smell, transmission, whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
