Error Codes....
Old 03-02-2009, 11:25 AM
Nader's Avatar
Nader
Nader is offline
Default Error Codes....
Hi Guys,
I just bought a used 2001 Grand Caravan Sport.
Ran a diagnostic to determine why the check engine light is on and I received a P0605 Internal computer error! (ROM) and P0700
Can someone give me a more detailed explanation what these codes mean and suggestions to correct these problems.
Thanks in advance....
Rod
Old 03-02-2009, 01:11 PM
surfit's Avatar
surfit
surfit is offline
Enter the error code in the "search" function of this message board.
You will probably get pages of messages.
Old 03-02-2009, 10:38 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
P0700 means there is a code in the TCM ( transmission control module ). P0605 means you have an internal tcm code for ROM, computer term ( read only memory ). According to my pdf files, the fix is to replace the tcm. But I have been able to reflash the controllers thru DCX aka chrysler, I would try a flash first before replacing the controller.
Old 03-05-2009, 06:22 PM
Nader's Avatar
Nader
Nader is offline
Default Thanks...
...great suggestions.
I spoke with my local Dodge dealership and they're not real happy about flashing the TCM. In fact the tech didn't even speak to me he just walked off, I had to speak with the supervisor. Even he was short, all he said was we'll flash the TCM for $90 and that's it.
I'll let you know how it turns out....
Old 03-09-2009, 06:13 PM
Nader's Avatar
Nader
Nader is offline
Red face Dealer follow up..
....after speaking to a different service manager about flashing the TCM on the Caravan. They offered to do a diagnostic service, which was $20 dollars cheaper and included a TCM flash.
Unfortunately, the flash didn't work on the transmission, so it looks as though I'll have to replace the unit and have it flashed again......but, now I know.
Anyone have a good resource for TCM modules? $550 is a little steep from the dealer to replace the module.
Regards,
Nader
Old 03-09-2009, 06:44 PM
master tech
Even if you replace the TCM, you'll still need the dealer to put the vin and set pinion factor. I think thats a good price. Our shop would be around $650.00 .
Quick Reply: Error Codes....
