PO700 and little square around gears isn't accurate
Old 03-31-2009, 07:43 PM
shammons90's Avatar
shammons90
shammons90 is offline
Unhappy PO700 and little square around gears isn't accurate
I have code PO700 and I know that's posted frequently but my dash isn't reacting when I shift, it takes a minute and then registers the correct gear. I haven't noticed any other problems. Please help, I don't know where to start.
Old 03-31-2009, 11:20 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
What year is the mini-van? And does the problem take 60 second or 6 to 8 seconds.If you were able to get the P0700 code, were you able to pull transmission codes? If you haven't, pull the codes and post them.
Old 04-05-2012, 07:57 PM
Roneisa77's Avatar
Roneisa77
Roneisa77 is offline
New Member
Default 2004 Dodge Neon
I have a 2004 dodge neon can someone tell me what does code p0770 transmission control system means and how much will it cost,code p0562 system voltage low means.
Old 04-05-2012, 08:02 PM
Roneisa77's Avatar
Roneisa77
New Member
I have a 2004 dodge neon i took it to advance auto parts today because when i start the car it seems as if it's dying and these two codes came back p0700 transmission control system,p0562 voltage low can someone tell me what these codes mean because i just had the transmisson fixed?
Quick Reply: PO700 and little square around gears isn't accurate
