When the ignition is engaged, the car turns over but does not start. Seems to be getting plenty of juice from the battery. Fault codes are P0353, P0352 and P0351... pointing to spark plugs, wires or ignition system or coil.
About a year ago I had the same problem. Replaced plugs, wires and coil. I think the coil was bad as putting that in fixed the problem. I believe I had the same codes too.
I cleaned the plugs and replaced the coil, but still not starting.
I bought a spark tester and 5 wires give a spark, #3 doesn't seem to spark much, if not at all. The odd thing is that when the #3 plug wire was on the tester, grounded, the van started! I removed one the other plug wires and used that for #3 and same non-spark, but it starts.
Removed a spark plug and it is wet with gas. I would think his seems negate a fuel filter/pump problem.
What could it be?
Any help would be appreciated!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Vehicle: 2002 Grand Caravan Se, 3.3, 1994 Dodge Dakota 3.9 4x4 (plow/work truck), 1998 Dodge Dakota SLT V8
it definitely sounds like an ignition problem. Look at the coil first. That plug is just wet with gas because its not firing & burning it off. The fuel is getting there so that's not the problem
Your P0351,0352 and P0353 are the same problem, primary ignition coil. You could have a ASD relay problem, short to ground or no ground, or PCM.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
