The metal heater lines that supply the rear heater are leaking behind the engine. It seems to be under the alternator area (where I cannot see!)
Question: Can I cut out the bad section and clamp on heater hose or do I need to have a flange or lip at the end of the pipe? I am afraid hose clamp will not be good enough on a pipe with no ring around the edge.
Do I have to remove the intake to take out the pipe system?
I appreciate any options you may suggest.
I am considering just bypassing the whole system with copper lines.
Ideas? Concerns?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I had this problem with an old tempo before. If you have a small pipe cutter(little $5 c shaped sucker), and you can get your hands in to maneuver things around, then you should be able to do it. The pressure isn't really high enough to need a flare, so you can get away with hose clamps.
__________________ As a DF moderator My opinion is only my own and does not represent the DF community, it's staff, or affiliates. I moderate solely based upon guidelines and not in regards to my own personal beliefs. Rear Wiper Club Member #2
Quote:
Originally Posted by PappiDread6
Hello My Name is Pappi Dread and I have an addiction, Male DF Members
I fixed my metal lines last night. I cut the lines behind the engine and spliced in copper tubing with 5/8 rubber hose (2 clamps per side of connection).
